iampoor1
Tubetec said:Sounds like you might have your buddies amp sorted , I hope he at least brings you round a six pack of beer and a baggie of bud for all your trouble . Yeah theres always a DOH moment when you end up sorting out ball buster of an amp , I was going to suggest incense ,sitting contemplatively and a prayer to the little guy with the podgy belly for inspiration .Anyway your a little older but wiser than before now and you'll spot a funky CF circuit quicker next time around , all the best and let us know how things turn out in the end with it .
hahaha, yes, maybe a nice bottle of whiskey after this whole ordeal. ;D It was frustrating because the amp would be stable for days, and then he would receive it, and it would start freaking out again. I spent most of my time just trying to make the failure mode repeatable, that I didnt do my due diligence and look at everything closely enough. I hope anyone that reads this thread in the future will not make the same mistake.
Kingston said:What was that electrical law again - by a member of our forum - 99% of the times when the problem doesn't turn out to be a mechanical failure - it will turn out to be a mechanical failure in the end.
LOL, duly noted. ;D
pvision said:Anecdotally, many injuries caused by working on valve gear are caused whilst recoiling from the shock. If there's something to hit your head on, you will do. Might sound like a joke - but it's not
Nick Froome
Hi Nick, interesting. This may be a good excuse for me to clean up my shop floor. I have many things behind the bench that could easily be tripped over if I fell backwards. My workbench is pretty clear.
Tubetec said:Touch wood ,never got shocked from a powered valve unit ,once or twice I did get a tingle from undischarged PSU lytics ,and on one ocassion way way back I accidently shorted across live and neutral solder joints with my finger tip ,left two little burn marks and a slightly odd smell in the air . Tesla used do all kinds of crazy stuff with voltage way back ,of course he was always carefull that the input/output path wasnt across his heart . Valid point about the convulsive effect of electric shock though.
Was a guy and his son in a place I used work years ago ,they did painting and other odd jobs around the place ,one day while painting the outside of the building they moved the scaffold they were working on too close to overhead high tension cables ,there was a spark ,the father was thrown clear ,the son caught the full force of it ,apparently the soles of his shoes were melted into the ground.
Always respect the power (of electricity).
Yes I had a similar experience. Got shocked by about 400v DC from PSU caps that did not discharge. I learned that not all modern production amps have Discharge resistors on them that way (it was a peavy valveking). Thankfully it was just across a finger. Left a small burn and a funny smell.
Wow, yes definitely dont want to use metal ladders or tools near HT power cables. Hope they were okay!
