Djankies said:Yes the meter moves to a little below +2VU when in +8 metering and maxes out when metering in +4 with the current adjustments and settings that have been done so far.
Daniel
Djankies said:No, in both metering modes (+4,+8) the meter moves with the input knob. If I lower input, the meter shows a reduction in level.
Daniel
Djankies said:Hey Mike,
One more question. I tested for the typical voltages posted on Mnats' site with the same test conditions he lists and everything measured correctly except for the base of Q8 (measured around +19 VDC where Mnats suggests a voltage of 16.93 VDC) and the collector of Q13 (measured -1.5 V against Mnats' +9.76V). Is this anything of concern?
Daniel
Djankies said:Q13 Seems to be at the correct +9.76VDC now. Not sure what the deal was the first few times I measured. ???
Daniel
Djankies said:Hi Mike,
Just received the fuses in the mail today! Thanks so much for those.
Today I put a new fuse in and started playing around with it for the first time. I'm quite new to rack gear and i'm not really sure what standard values I should be looking for. I was measuring THD of the unit with a 500 Hz sine wave at .775 Vrms. I wasn't able to crank the input knob past around 30 before there was extreme distortion. Is this normal? what's a normal signal level that would be going through the unit? Also, when turned, the input knob produces static, but only when there is signal running through the unit. Is there a way to solve that?
Another issue that i'm confused about is wether or not the frequency response is as it should be. For mono files playing through the unit, almost all the bass disappears. is this normal?
Daniel
Daniel
Djankies said:Hi Mike!
It's funny that you suggest using a probe, I was looking around the internet last night and came across this video (https://www.youtube.com/watch?v=IEcyDzYAsuU). I am planning on going to radio shack to get all those parts today. I definitely think that will be my next step.
Something leads me to believe the problem lies somewhere within the input stage of the circuit because It seems the output knob has nothing to do with the fuzzy/crackling distortion, surprisingly nor does the input knob , its really the level going in that is the problem. So maybe this is an before- the-board issue? let me know what you think.
I'm measuring THD with a program we used in an acoustics class last semester called SignalScope Pro. (don't worry the equipment im using to get audio in has around .002% THD)
Orange and yellow are tied off and soldered
Daniel
