ilfungo said:Thanks Rob
I can use it in new Mnats rev F ?
thanks
It would appear so from looking at Makos white market page where it says it is suitable to use with the new B11148 transformer that Ed designed ! What do you reckon ?
thanks
stereokillah said:hello
i'm finishing the my second rev A, and when i started to calubrate it i found a problem:
when i put a sine signal 0.775 vac in input i need to put input and output full to have a smal signal in output xlr, and don't have compression .
stereokillah said:hi Biasrocks , thank you i'll try it
hi ChrioN , there less problem than the gssl i think, there is some resistors changement , the link is in this thread, if i find it i'l post it.
Rob Flinn and others did the work on this and their efforts are reflected in the BOM linked from the first post. Look for the optional resistor values. One change has been incorporated into the BOM as there was a mistake on the earlier versions of the BOM and screen layer of the board.stereokillah said:there is some resistors changement , the link is in this thread, if i find it i'l post it.
gary o said:hi folks is there any further news on the this Rev A wired as a 1108 mic pre.....thanks
