Could it be a wiring error? I would remove the wires from the DC output header and check the PSU voltages again. You can check the 48V on the PSU side of the fuse.
No way, you must be using a wrong measuring reference.4D Audio said:One side reads 48.6V and the other side reads -16.4V.
There are 10 wires to remove not 11. You will probe for DCR between the AC entry points for each sections diode bridge. Take a look at the schemo. For example, JP3-5 and JP3-6 are for the -16V rail. If these 2 AC entry points are somehow "connected" or shorted together (somewhere), it will near immediately take out the mains fuse when you power up. You most likely have one (or more) shorts between the pairs of AC entry points on the JP3 header.tgr said:Hey, thanks for that. Sorry to be dim but, can you provide more detail. If I remove the 11 wires from J3 where are my test points?
