yepp. (just hope, the fuse was blowing faster than your transformer windings and maybe resulting followups)foesters said:So this should be right.
Yeah the reason I say 1.5a fuse, is because I don't see any 1.25a fuses.
In my package from volker there was only the 160mA, 2,5a and 1,5a?
Do need to get a 1,25a fuse from the shop ?
will trip again with neutral (your white wire) and safety ground (your green/yellow wire) flipped at your IEC socket.brettooo said:Yes switched to 230v , main fuse in tact. Though I did trip my wall sockets fuse first time ...
Using the mains voltage selector switch, without this jumper you will miss the needed transformer primary windings series connection for 230VAC mains (not parallel for 115VAC mains). Have a look some posts above for another european hookup (obviously using a different transformer)... as i had a jumper going across the bottom row of the 115v/230v switch as in the build pictures ( though took this out).
Harpo said:will trip again with neutral (your white wire) and safety ground (your green/yellow wire) flipped at your IEC socket.brettooo said:Yes switched to 230v , main fuse in tact. Though I did trip my wall sockets fuse first time ...
Probably, but hard to see on your pics and you want to build this correct and safe.brettooo said:Does this mean if I swap them over ( and add the jumper on the Voltage selector switch) I am ok to do the Voltage checks or do I need to do further re wiring ?
Yes that is fine. For the US toroids, the black leads for the 48V windings indicate that is a dual VPR toroid. The white leads are for the 51x version. Besides the part#, that is how I tell them apart.brettooo said:....Though my transformer has black leads that go to ac48v on the pcb (instead of white ones) though I read earlier in the thread that that was ok?...
jsteiger said:Yes that is fine. For the US toroids, the black leads for the 48V windings indicate that is a dual VPR toroid. The white leads are for the 51x version. Besides the part#, that is how I tell them apart.brettooo said:....Though my transformer has black leads that go to ac48v on the pcb (instead of white ones) though I read earlier in the thread that that was ok?...
the +16v rail of the Phoenix DRS1R/500 is 118ma (which is within the API VPR spec) and being that the unit is Class A discrete the inrush is very slightly higher.
