I just added another 50pc batch of these to the store.
Hi Pete, I would suggest posting over at RGO and tagging John Kennedy. He has one of the first 8 units that I built up. I know many folks are working on them but I don't think anyone has made it to the finish line yet. If John is not super busy, he may be able to post some clips. FYI, Rob Schnapf had a demo for a few weeks. He tried it on everything. I could probably get him to reply if you post your question on the FC526 thread at RGO.PeteJE said:Can anybody comment on these sonically when it comes to clarity / transparency in a light ratio (2:1) on clean vocal? As something more like a mastering touch on a vocal? Hoping to get depth and clarity and fullness in a light mode without too much harmonic or fuzzy coloration. Clearly these are fantastic for color and crushing parallel compression hugeness (I listened to the drum examples on realgear online - awesome), but wonder about a less colored use. For some reference have been using massey CT5 in plug in world and the JLM LA 500 in the analogue and have used just about all different models of the analogue classics over the years.
I am far from a DAW guy but did some googling and found this for a Windows machine. I found the link in a SoundOnSound article http://www.sillanumsoft.orgstribor1 said:One unit up and running, did the 3x1731 myself, everything fired up right from the bench. Just finished the calibration, quick soundcheck, works great on drums!!! I'm ordering a second one.
Anyhow, any instructions on the THD N measurement? Don't have any analyzers just my DAW (Windows, Cubase, RME HDSPe AES32, Mytek 8x192)can someone recoment an plug-in or easy to use app?
One will be the 13V zener. The markings on the side with be :PeteJE said:On main PCB parts, can anyone id the two loose glass diodes on the BOM for me? I id the 9 (on tape), the two small black are the FDH333 I believe, the two larger black are the 1N4004 I believe, but don't know what the two loose other ones are (look like the 9 on tape).... thanks. (chunger!! I'm scared without the pics, ha)
jsteiger said:One will be the 13V zener. The markings on the side with be :PeteJE said:On main PCB parts, can anyone id the two loose glass diodes on the BOM for me? I id the 9 (on tape), the two small black are the FDH333 I believe, the two larger black are the 1N4004 I believe, but don't know what the two loose other ones are (look like the 9 on tape).... thanks. (chunger!! I'm scared without the pics, ha)
24
3B
The other will be the 4.3V zener and will be marked 4V3.
You will need some sort of magnification to read these labels.
None of the trim pots should be turned before it is specified in the calibration doc. They are all in their factory set position which is somewhere near 50%. Turning them all CCW is for sure not a good way to start especially if you look at step 14 of the calibration doc which states that the Q-Bias trimmer should be turned CW. I also have it bold and underlined in the doc.JeromeMason said:Having an issue here, when the comp is engaged getting a very thin sound, almost like a HPF as been rolled up to 400hz. Could this be in the Q-bias setup? I've always turned my trim pots CCW before I adjust, did you have this preset or anything?
Hmm, I would check continuity on the switch pins before removing it. The chances of a bad switch are pretty slim.rabe said:Thanks for the quick response!!
There is continuity between the #2 to #10 fingers
and the #4 to #8 fingers in both BYPass and ACtive modes.
Should I replace the switch? I have another from a second FC526 kit that i haven't started yet.
