[BUILD] CAPI VP28~500 Series~2-Stage Preamp~Official Support Thread
Hey! Done building 1 VP28, im getting sound and all the buttons are working functionally, LEDs working, phantom working etc.
have some test results. But the signal is very weak, measuring somewhere -70 to -30 db on my audio interface, with a sm57 and fader and pre gain all the way max. Testpoints 1-5 seem to measure values that are good. but 6-7 not really anything there.
  1. 109mA
  2. 696mA
  3. 1.26V
  4. 307mA
  5. 309mA
  6. 0
  7. 0
Hope someone could help! Thanks.
Between TP5 and TP6 is the HPF PCB so check that along with the 5-pin header and the mini toggle switch as signal passes thru it.
Looks good there, reflowed the solder joints, could it be the op amps? Whats between tp6&7?
If its down at TP6 most likely the issue is between TP5 and TP6.
The fader amp is between TP6 and TP7.
If you aren't testing with 2 known good working opamps then trying to "fix" the module is like a dog chasing its tail.
Ah ok, too bad. Might have to buy some preassembled opamps then!
You can remove the fader amp and check for ACV at that opamp's non-inverting input socket. If there is not signal then the issue is previously where I said to look. I would dbl check TP5 and TP6 at the same time.
Everything works PERFECTLY! Thanks so much for the help! And it sounds really nice!! So good on snare & kick so far tested, driving the preamp and backing off the fader, really makes them pop!
now gonna build another one! at least I know what went wrong for next time =)
Please share to maybe help someone else in the future.
I went over every soldier joint and reflowed them and looked closely, It was ultimately the fader opamp not working correctly. I think. Suddenly it just worked, I'm not 100% what I did to fix it, sorry.
How do you know that "...it was ultimately the fader opamp..." then???
I am now building the second vp28 now, Everything works fine with the previous opamps. But one of the new opamps I built is not working properly. It gets really hot, what is most likely? a short somewhere or did I possibly overheat a transistor? I'm pretty sure everything is in the right place.
Swap opamps between units and see if the issue follows the opamps or stays with the preamp.
With different opamps the unit works perfectly. Its one of them get very hot and sound sounds gated, there is sound but, it is also distorted, and quiet.
To be more clear, the same opamp causes issues in the other unit as well. It gets extremely hot to the touch
So its an opamp issue not the preamp module.
Yea it the opamp, any ideas what to troubleshoot? Could the resistor be overheating? Ive checked for shorts as good as i can with a magnifying glass. Maybe ill order a new one and try again
Look for the specific opamp support thread since its not VP28 related. As always, skim thru the thread before posting.
