100WChris said:Thanks Rodney!
metric is cool, i live in germany
i made a template for FrontDesign.
It´s based on Rodneys dimensions but it is not verified!!!
Maybe someone can compare it to a real faceplate, just to make sure i made no mistake!
You have to rename the file to "fpd" (it is not allowed to upload an fpd-file).
Chris
gunpoint recording said:Nice. here's mine. I did it so it matches all of the other modules i have done. The switch holes are bored in the back so that the mounting nuts will go on underneath. Added 2 small screw holes so i can use small black screw to mount the plate to the bracket, instead of the switch nuts doing this job. I noticed i have my phase markings reversed though from the one above. ill need to double check that.
