[BUILD] TBFX
horvitz
Beverly, MA
This will be the build/discussion thread for my TBFX, which you can find here:
http://tbaudiogear.com/?product_cat=tbfx
So first the whatsit question.  The idea was to make an inexpensive and ease to use format for line level effects and gadgets.  To accomplish this, I created a carrier module which fits in a 500 rack (maybe a more dedicated rack in the future?) which has all the common guts that everything needs: balanced line receiver and transmitter, relay bypass, and dry/wet blend.  Doing so allows for modules, called plugins, to be very lightweight, and thus inexpensive.
This stuff is super easy to build and fun to work on.  Right now, I have available for plugins the TBFX-CH1, which is an analog chorus and the TBFX-DP1, which is a DI with DOA gain stage making line out.
There is developer information available here:
http://tbaudiogear.com/?page_id=399
Anyone is welcome to build whatever they like for the format, and I will of course support any such endeavors.  Note that I am currently working on a simpler and less expensive bracket format for the plugins.
More plugins are already on the way.  Hopefully we can have a little fun with this.  You can begin to imagine all the circuits that we can quickly and easily jam into this.
Brian
So what do you guys like in a proto board (click for bigger)?  I've got +V on top, -V on the bottom, ground in the middle.  Any suggestions to make this more convenient to work on?  Will have these in the store along with blank brackets for knocking up circuits.
Well, I guess I should be clear that this is for use in my TBFX so card edge isn't really relevant.
I had been back and forth with myself over standard control footprints.  I guess I thought that something like a GH71 footprint might interfere with other more common things like a pot.  Kind of on the fence about it..
Denyle Guitars said:
What's the spacing on the proto board, 0.1", I assume. Maybe have a few fatter pads for a 2520.
It is indeed .1" spacing.  They are .032 holes with a .060 pad.  I could work in a DOA socket easily enough.  Would you think .040 holes just so the pins fit or a .100 hole for the mill-max sockets that I usually use?  The only potential issue is that it would straddle the ground rows in the center but I think that's ok.
AudioHammer said:
Any progress on the TBFX proto board?
On the way!  I should have them by the end of next week.  We won't initially have the brackets but at least the boards and connectors will be here, which is enough to get a circuit working.
Got the proto boards in and built a little test circuit.  Seems to work out!  This is a messy little 5534 based pre.  Although I don't have the brackets yet, the board and DIN connector will be available shortly.
