PhilipMarlowe
- Joined
- Nov 28, 2019
- Messages
- 98
This impedance stuff is a bit confusing, to say the least, so I want to ask more knowledgable people before jumping into this DIY project.
So I want to build a DI box 19 inch rack as cheaply as possible but with quality transformers (specifically the Lundahl 1935s since they can be run passively afaik. I also listened to many comparisons and I just like Lundahl transformers the best from all other commercially available ones.
It should effectively work like the Radial JD6, only with different transformers and less features I don't need.
From what I gathered the circuit should not be a complex one, and if I see correctly it would in theory be possible without printing PCB boards.
My use case would be running instruments (guitars, bass), synths, drum machines (MPC Live and Elektron) and lastly DAW Line signals from my interface's DA (reamping) for mixing through this DI into my mixer which has mic pres on 6 of its channels. Effectively I would have a chain that goes through multiple transformers before going into the box again (fuck yeah!)
Would there be any impedance issue regarding the Lundahl 1935 that I should be aware of, since I want it to be able to handle any source I throw at it? Would I even need a pad?
Just to clarify: I have some experience building DIY equipment and modding gear.
Thanks guys!
Thanks guys!
