therecordingart
Couple questions....
-The 220uf and 2200uf caps....which caps on the PCB am I replacing with these? Next to the power plug there are two different sets of two 1000uf caps, so I don't know which to swap. I'm also not sure where the 220s go.
-As far as the 1uf cap that goes to pin 2 and 5 on THAT 2252....solder to the underside of the board?
-Replacing the power plug....just pull it from the PCB and solder a different one in its place? Am I only doing this so I can use a different power supply?
So far I'm planning on replacing everything listed in these mods except for the diodes. Do those really have to go or should I be ok?
