http://www.analog.com/library/analogdialogue/archives/39-09/layout.pdf
I found Samuel's link in the Ground plane thread and posted it above. This is mostly about monolithics but what about discrete circuit stuff? Like a simple JFET buffer?
Like this:
http://www.avensonaudio.com/tech/MP-2NV%2520DI.jpg
It seems that C28 and C29 are following the rules in that article for being close to the Voltage supply on one end and then being close to the load resistor R66. Those rules are implied in that schem, right?
Also, that chart seems more concerned with High frequency ckts over 1MHz. Does anyone have a similar chart for Audio Frequencies? Are there standard ratios between cap values that are best?
Like this:
