neverlistentome
Member
- Joined
- Apr 8, 2005
- Messages
- 24
Can anyone help explain how jacking a hi-quality poly cap across a cheap electrolitic exactly works? I realize the theory is that poly-caps handle the hi-frequency material better and there-fore "take the burden" off the larger value electrolitic chosen to pass more low end, but doesn't the cheap electrolitic still pass the distorted hi-end material?
Does this arrangement cause any weird accidental cross-over effects? Is there any guide line for selecting component values when mixing these two caps together?
Also I've heard of bypassing rectifier diodes in the power supply with .1 uF poly caps to cut down on switching noise...does this make any sense? If this does should the caps strap across the actual diodes of a bridge rectifier or should they go from the + and - ouputs of the rectifier (I guess just like a first filter stage?)
