???If you want some advice, use the Neumann circuit for the U47 with the 6CW4 nuvistor. I believe it is the best overall, considering the original U47 FET and U87, which I have owned for years.
This thread is about a C414 EB
In bulk? Maybe like 50 cents for a small amount. Like 15 cents for a large amount. It's the mold that would cost money, not sure how much for something with this many holes in itI will keep that in mind, thanks.
Here's a model taking those measurements into account and adding additional pass-through holes. This should be accurate. Anyone want to check it? @soliloqueen - what would the rough per-item cost be to do these in neoprene?
FYI, I attached a .stl file, but to attach it, I had to use @MidnightArrakis's method of adding ".pdf" to the end. Just delete that, and the file should open. Also, this file is in mm - since it's easier for me to work in, and it's for a European mic anyway, haha.
[MidnightArrakis's method of adding ".pdf" to the end] -- THANKS!! for the mention!!! I appreciate that very much!!!I will keep that in mind, thanks.
I don't know anything about 3D printers, but I have a bunch of coworkers that print a lot.Capsule mounts alone are honestly one of the things that made investing in a good 3D printer nearly the smartest tool buying decision I’ve ever made.
Honestly by the day I am more convinced that it’s a tool every shop and most households should own.
[I attached a .stl file] -- And.....here it is:I will keep that in mind, thanks.
Almost all filament materials would have suitable dielectric properties for the job. I often use carbon fiber loaded filaments for prints which i would probably avoid just on the off chance they might pose an issue.I don't know anything about 3D printers, but I have a bunch of coworkers that print a lot.
What kind of materials do you use and what sort of insulative properties? Is it easy to achieve hi-z isolation? Can you make mounts with any sort of elasticity?
I've thought about the 3D printer rabbit hole, but I'd like to know I'd use it a lot before I really consider it. I've thought about making little shock mount wrenches. Some shock mount nuts are super hard to loosen after someone over tightens them.
I’m working with Protolabs, and they said they could print it in 70duro TPU, so that’s what I’m trying out.Almost all filament materials would have suitable dielectric properties for the job. I often use carbon fiber loaded filaments for prints which i would probably avoid just on the off chance they might pose an issue.
But even cheap and easy PLA would suffice. It’s got the weakest dielectric strength of all common filaments and even at that it’s still like 30kV/mm.
If you wanted to be fancy you could print in polycarbonate- but its touchy and difficult to get good results. And ABS is much easier and has something like 70kV/mm… but really obviously any of the common materials would be fine.
Yes you can print in soft materials that would have shock absorption properties. TPU is a flexible urethane and i have used it for mic pedestals and mounts for saddles before- and once for a full capsule mount for a Dachman mic where the whole capsule was surrounded so i wanted the mount to allow it to “snap in”. It worked perfectly but you ideally want a printer with a direct drive extruder- you can get away with a properly calibrated bowden setup for 95duro TPU but anything softer will fail to print properly. There are a number of printers on the inexpensive side that have direct drive setups.
I’ve usually used 90 duro and if you modify the infill and structure you can dial in the “bounce” you want- but yes being able to print in a softer duro from the start makes life a lot easier!I’m working with Protolabs, and they said they could print it in 70duro TPU, so that’s what I’m trying out.
For mass-production (anything more than 5-10), I think you're absolutely right. I have no idea how much actual need there is for this though. If my 3D-printed part works, I'll let everyone here know and I'm happy to share my files in whatever way would be most helpful to others.To be honest I believe it might be easier if you were to use your 3d printer to print up some molds for this piece and then fill them with silicone or rubber. In that way with a few molds you could quickly make hundreds of them in a much shorter time and they might be closer in flexibility to the original part.
