evil grill
Payment sent for 4 kits.
Looking forward to this project.
elskardio said:Thanks to everyone who placed an order. Your kits will ship by the end of the month.
You'll receive a private message with the tracking number of your package and the download link for the build guide.
evil grill said:Hi!
I have'nt recieved a tracking number. Is there a delay?
Bobby Baird said:I have built my pair, but at the unity gain calibration step. I have the trimmer maxed out, and I'm still 7db short on gain on both units. I checked all resistor values before populating. Any suggestions? Thanks in advance.
elskardio said:Hi Bobby,
What’s your test setup? DAW with an audio interface? Are you feeding a balanced signal to the module’s input?
EnjoyBobby Baird said:Racked calibrated. Thank you!
Bobby Baird said:So... one of the CA-250's high band is not functioning correct. While injecting pink noise using span spectroanalyzer set to 1 octave smoothing to visualize curves. I have the high band shape set to sharp. Frequancy knob set all the way ccw. Gain 12, and the lowest it will go is like 7.68k on span where the knob says 2khz ccw. My other CA-250 works flawlessly. I built both at the same time using the same bom supplied last week. I made sure to take my time. As, I have no schematic. I'm not sure were to start troubleshooting this part of the circuit. Hope to fix this bug. I did bump c28 with solder iron by accident, but it seems cosmetic, and I'm sure that's part of the low band.
critterkllr said:The only feedback that I have would be to specify that the standoffs are two different sizes.
evil grill said:Mine are still somewhere between Canada and Sweden. Really annoying as I was planning to use them on a recording end of May.
elskardio said:This is clearly specified in the build guide.
