CAD C9 Mini-Condenser Wisdom
Jim McKeveny
Active member
NYC Metro
Seems a stage tech managed to "liberate" the xlr/pcb from this econo-mic, and it ended up on my desk. I am hoping the resident wizards of this forum can decipher the markings on the capsule & pcb and advise on proper reattachment points. TIA!
    1.7 MB
    885.4 KB
    2.6 MB
    983.3 KB
Any chance you could steady the camera a bit better, for some slightly less blurry photos? And maybe a shot of the back of the capsule, but a bit more from the side, like 30-45deg off dead-center?
The capsule seems to be a primo one. Typical source drain ground markings. It has a built-in fet. So ground goes to ground on the pcb, and you are left with figuring out s/d connections. It could easily be they are interchangeable.
