letterbeacon
Hi there,
I'm planning building the RS124 soon, and I'm attempting to work out what power rating I should rate the resistors. I know I can do this via Ohm's law, but to someone like me who can put together a project by following a schematic, but my theory is a little rusty, I'm struggling to find the values on the schematic I need for me to implement Ohm's law.
For example in the attached schematic R26 is 100k and links the plate of the 6B6C and the 6CG7 together. I can see that there's a voltage of 175v at 20db compression on the plate of the 6B6C, but how can I calculate the voltage drop across R26?
I know this is super-basic, but in all the examples I find when I Google, they give you all the figure you need to work it out.
Thanks.
Thanks.
