carboncomp
Active member
Need a 10KC reverse logarithmic slider for a project and just wanted to know if this is correct or if I'm missing something:
Original Wiring:
Reversed Wiring:
Original Wiring:
- One end terminal connected to ground.
- The wiper (middle terminal) connected to the input.
- The other end terminal connected to the signal source.
- With this configuration, as I move the slider from one end to the other, the resistance increases logarithmically.
Reversed Wiring:
- One end terminal connected to the signal source.
- The other end terminal connected to ground.
- With this reversed configuration, as I move the slider, the resistance will now decrease logarithmically. (reverse logarithmic response).
