can I Replace Variable inductor in Fm Transmitter with varicap diode + pot?
Allex
New member
I've build this fm transmitter that uses a var coil to tune the freq. I would like to be able to tune via a pot.
Is this possible?
This is the transmitter:
http://www.eleccircuit.com/ba1404-hi-fi-stereo-fm-transmitter/
and this is a replacement i found for a variable capacitor, would this work?:
http://electronics-diy.com/varicaps.php
I'm fairly new to oscillators as well as electronics in general.
Thnx!
abbey road d enfer
Moderator
Marcelland
It should work, but there are two potential issues.
First, you need a higher voltage (8-20V) than the normal operating voltage of the transmitter (1.5-3V).
Second, the frequency stability; varicaps vary with voltage, so you have to make sure the tuning voltage is stabilized, but vary also with temperature and the alignment of the Moon with Pluto  ;D.
You may need to a fine-tuning adjustment for drift compensation.
Allex
New member
Thanks for the reply.
I'm planning on using batteries, 2x 1,5v for the transmitter and another 9v for a small antenna amp so i could power the varicap diodes with 9v.
What capacitance would I need for a frequency range between 85 and 108 MHz?
abbey road d enfer
Moderator
Marcelland
The real question is: how much variation is needed to cover the range. Not much; the effective capacitance variation range needed is about 1:1.6. The varicap is never directly across the inductor; there's always a cap in series with the varicap and one in parallels with the inductor. They reduce the actual variation range of the varicap.
With 9V, you get a usable range of 1:2.5 (10-12 pF to 25-30pF) for a standard BB105.
You may use the existing inductor for experimentation but it appears it will need to be changed anyway. It looks like it wants to see about 10-20pF. The varicap + fixed cap would be more like 20-40pF. You may unwind a few turns to tune it.
Allex
New member
I think i'm missing something here, so the varicap will not replace the vari coil?
and where do i need the 10 to 20 pF? at pin 9 and 10 or at both sides of the vari coil?
I've got a few BB409's so i could place 100pF in series with the varicap output to give me a range of +-12 to +-20 pF (9v to 3v)
If i don't add the 100pF I would have a variation of 1:1,6 across pin 9 and 10 is that what I'm looking for?
If you could tell me how this IC establishes the frequency I would really appreciate it.
abbey road d enfer
Moderator
Marcelland
No, the varicap replaces or rather complements the fixed cap that's across the inductor.
In principle it's across the inductor; but since one side of the inductor is AC-wise grounded (DC-wise it's at V+), the varicap should be connected one side to pin 10 via a suitable cap) and the other to ground.
I've got a few BB409's so i could place 100pF in series with the varicap output to give me a range of +-12 to +-20 pF (9v to 3v) If i don't add the 100pF I would have a variation of 1:1,6 across pin 9 and 10 is that what I'm looking for?
the frequency is governed by the formula LC (omega)² = 1 where omega = 2pi.F.
Now I don't know about the internal structure of the IC, so I don't know the value of the stray capacitances and the influence of the additional caps (between 10 & 9 and between 9 & 8) but the actual value of C is larger than the cap that's across the inductor.
