Can someone design me a logo?
To my eye Zam's  first one is best so far ,
I think the extra letters and scripting only takes away from it ,
What springs to mind is form the two C's from the envelope of the tube , and just keep the cathode /heater graphic standard .
+1 Simplicity and impact.  And since there's going to be like 30+ of the same symbol all over one unit, extremely subtle.  Much more so than what I was playing with this morning.
ruffrecords said:
Thanks Boji.  will try that out on a few panel designs.
Hello
Yes that's how it look inverted
I just email you the source data so you can export whatever format you need at whatever resolution you need
It's a dxf so you can also export for engraving
please do a print test as it never look the same as in a screen, for this version I have a little doubt about the gap between top of C and the curved T bar.
Best
Zam
option...
    11.3 KB
and last... I have to stop this  ;D
the "advanced" version (inner CTC is the exact same) for single use at top of the console, like between Vu
Best
Zam
    85.2 KB
zamproject said:
esoteric  ;D
I really like that. Attached is an fpd file of a channel module incorporating it. I like it. (fpd extension changed to txt in order to upload).
  • 8trackerCHv2.txt
    15.7 KB
the time to download fpd update and ...yep... "esoteric" seem to work better in small print, as 3d view
best
Zam
ruffrecords said:
Hey Zam, I just wanted to a say a public very big thank you for all your efforts (and talent). Much appreciated.
Ian, thanks a lot for that !!
Zam
I like the ones that incorporate the tube,  if you are willing to flip the triode you could get some good mileage out of using the plate for the T.
I like the 'esoteric' one. Looks like two ghosts back to back, eyeing the East and West, or maybe sleeping.  :)
Edit: Just opened the fpd.  Nice and low key.  You can tell it's a maker's mark, but it isn't screaming-out to be puzzled over.
Record. Mix. Play.  I could see that as a footer on a line card (advert).  8)
It reminds me of those big alien guardians in The Fourth Element.
I like that too - its what a mixer should do. Record. Mix. Play. That panel is the latest version of the Mark 3 channel amp which has a tape input as well a mic and line. There's a big button in the monitor section labelled Remix that flips all the inputs to tape (Play)
