strangeandbouncy
Greetings One And All . . . . .
I am just a novice to Electronics, but use All kinds of Analog gear everyday. I have lots of gear that runs on 24Vd.c. and would like to start experimenting with building more gear. One thing interests me, which might help to integrate my intended projects with my existing (Coutant) Power supplies, which are probably big enough to weld with.
. . . . . I Ponder This . . . . .
My Neve and Audix mic/eq's achieve extra headroom beyond the operating voltage of +24Vd.c. by using a 300/600 ohm output tx to step up output. Can I do the same by paralleling two op-amps say 5534s/5532/op275 and a 1:2 step-up tx? what about discrete op-amps like Forsells? or the bag of Helios line-amp cards I have?
If so, will i have to change any resistor/capacitor values? Does input impedence of op-amps halve? Would this matter in practice? Have I lost the plot ?
Ho Hum . . . . .
Thanks in advance.
AndyP
Ho Hum . . . . .
Thanks in advance.
AndyP
