I have some of those! I’ll give them a shot!A1015 (2SA1015) will work perfectly
These work fine:How do I measure the hfe? I have an oscilloscope and a breadboard.
You can set-up a rig on a breadboard; it's not terribly difficult but also not very practical.How do I measure the hfe? I have an oscilloscope and a breadboard.
I will buy the device that abbs linked from Amazon.A good pairing of these final transistors helps to minimize the distortion that can occur at the output
My link was cheaper!!!!20 bucks! Looks like this is the ticket! Thanks Abbs!
Oops! I only saw the second link!My link was cheaper!!!!
I have a 2n3819! I will try this! Thank you!The micparts kit contains matching parts and pre-biased jFET for maximum headroom. Each jFET can be very different, so the bias must be adjusted individually, either J305 or 2N3819. I like the latter better.
So do I just use a multimeter on the third leg and just for 0 vdc?A possibility to adjust the bias for the jFET.
Adjustable resistor can be 470k...1M and R12 is 1Gohm
Of course the original schematic of the micparts kit must be modified
Put an alligator clip (known in some circles as a roach clip) on each lead between the body of the part and where you are soldering. It diverts the heat away from the part.My desoldering skills need some serious work. As you can see the throughhole eyelet I managed to tear off, I had to insert a pair of copper eyelet in on C14. I managed to get everything off, but I don't think the A1084's survived my noob attempt. I need to learn to be patient before pulling at components. Any tips on desoldering transistors? Im scared to hold the iron too long on the pins, so I eagerly pull at them while heating up the joints.
Mouser seems to not carry those BC560. I have a few other transistors some old broken devices i collected throughout the years, I can try and desolder. So far I see,
J108
C2240
KN3904
C1815
A1015
KIA79
KIA78L
431A
MPS A92
2N3819
LSK389
LKSK489
K170A
U441/ST
A561
C1681
A970
Some of these are really old...so Im not sure how time affects transistors...or heat from desoldering attempts.
Ooooooo I have some alligator clips! Non copper though, does that matter?Put an alligator clip (known in some circles as a roach clip) on each lead between the body of the part and where you are soldering. It diverts the heat away from the part.
If the iron is in contact with the solder joint for 7 seconds, pull away, let it cool, and try again. Never yank on a lead unless the solder is fully melted.
Nope. As long as they are metal.Ooooooo I have some alligator clips! Non copper though, does that matter?
Cant find any 2sa1084...can i replace them with 2n5401?
