ruffrecords said:What we are talking about is spikes caused by rectifiers. I was pointing out that there are two significant di/dt events in the rectifier current but only one spike so perhaps we are not talking about the correct mechanism.
moamps said:The di/dt is zero at diode's switching on and off (approximately) moment. There are two time areas of high di/dt, positive where diode's current supplies the load and charges an elco, and negative when the diode's current drops and the elco takes over the load.
The real cause of spikes isn't high di/dt per se but high remaining reverse charge Qrr of the diode when it is switched off as Tim already pointed out. This reverse charge is higher if the di/dt is higher at the moment when the diode should be switched off and if diode's transition time is higher. This Qrr is zero when diode starts conducting so there can't be spikes at diode's switching on moment (and dynamic resistance of the diode is very small, etc.).
So, if we like to have smaller spikes, we should have smaller di/dt or we should use diode with lower Qrr (schottky) in the first place.
But, if we already use a diode which generates spikes, we can dump it more or less by using a RC network on diode or transformer's secondary where R is set for critical damping of ringing and C is just a pass capacitor.
ruffrecords said:.....It seems to me this is independent of di/dt during the conduction period - once the junction is flooded it is flooded and will remain so until the diode becomes revers biased. Furthermore it states:
......"Schottky’s suffer from high reverse leakage and are only suitable for use in low voltage
circuits (up to 100V). "So they will be no good for HT supplies.
....... My question was why critical damping?? By definition it allows a significant high amplitude part of the spike to remain. Surely we require a severely over damped response to remove the spike almost completely - in other word R equals zero?
Interesting. Where does that come from?moamps said:Qrr depends of dI/dt. Look the attached picture with an example.
Thanks for the tip. I will check them out.For HT you should check out SiC Schottky diodes.
Again we are going back to the beginning.You cannot dump an oscillation without a resistive element. Period. By adding only a capacitor, oscillation is just moved to another frequency. If you add a small resistor, the pass capacitor should be large and the losses become very high.
I can't find the source on web right now. It's a data for a FRED diode. But you can find this type of data in datasheets for any modern fast, SIC and similar diodes.ruffrecords said:Interesting. Where does that come from?
Yes, but the ringing-oscillating is still there because this resistance is very small in a high power linear or SMPS transformers. This dumping is maybe not needed for HT linear supplies where currents are small and secondary real part of impedance is significant. Anyway, some designers, for example, use resistors (20-100ohms) in series with bridge and some capacitors across the bridge in HT power supplies for that purpose (Menno van der Veen), or just use simple RC network across the secondary.There is still resistance - the winding resistance.
Thank you. I will check that out.trobbins said:The BYT79 14A 500V fast-recovery diode datasheet has a good example of Qrr reduction.
http://trigger.ru/content/Catalogue/pdf/BYT79.pdf
There may even be a benefit from using series ss diodes - perhaps by taking longer to transition through the on-to-off voltage (as it is doubled/trebled ...), and assuming the same reverse current/time has to flow, as it will consume the Q in each device at the same time.
ruffrecords said:I use an X-rated 100nF capacitor across the bridge input in my HT supply designs and this completely kills the spikes.
moamps said:Are you referring to spikes on picture you posted in post 34?
ruffrecords said:I am not sure fast turn off devices have any benefit because they will just increase di/dt at turn off.
trobbins said:The key advantage of fast turn off diodes is their low Qrr. As Merlin's plots show, the fast diode almost achieves a simple step in voltage. Another batch of test results from Mark Johnson also show similar outcome, where low Qrr devices cause effectively the same step in voltage (due to pre-existing V=Ls.dI/dt, stepping to V=0 when dI/dt becomes zero). Standard diodes with significant Qrr allow a noticeable negative current to flow, and the recovering dI/dt to get current back to 0A adds an extra transient increment to the voltage step.
In the context of noise from a rectified B+ supply coupling over in to a heater winding, then I'd suggest there is no benefit in adding a snubber across the heater winding, as the coupling mechanism is likely to be capacitive coupling between windings on the power transformer.5v333 said:does anybody treat heater windings with caps/snubbers as well?
5v333 said:does anybody treat heater windings with caps/snubbers aswell?
keeping rf crap away from filaments and leaking through to cathodes etc...
Awww man, I certainly do remember. Memories, the arguments at the shop about which is the best brand of contact cleaner to use on them, the revelation that you can adjust the two slugs of the selected channel by simply pulling off the knob and using the provided hole to align, with one of the plastic hex drivers in the set....ruffrecords said:,,, in old VHF TV turret tuners
Gene Pink said:The UHF tuners had nuvistors, saved a bunch, wish I thought to save the sockets, too. Condenser mic amplifiers?
Gene
