Baltazar
Order placed! 1xVP312 2xVP25, and some other goodies ;D
Yes order received! Will be shipping tomorrow.Baltazar said:Order placed! 1xVP312 2xVP25, and some other goodies ;D
Absolutely yes it can. You just need to desolder and remove the Bourns pot. There are only 2 jumper wires that run from this little adapter PCB to the main PCB. Supper easy to retrofit. Shaft is also 1/8" (like the Bourns) so the knob comes off the Bourns and goes right on the Grayhill. The faceplate indication dots even line up. There is actually a 12th step which will be at the 6:00 position. Simple, small and highly useful.bobine said:And can be retrofitted?
jsteiger said:... They will also be used for my up and coming EQ.
This has recently evolved into 2 separate modules. I started out wanting to do two, then I went to one, now I am back to two!!baadc0de said:jsteiger said:... They will also be used for my up and coming EQ.
Tell us more! ;D
