CAPI-Gear; New CA-0252 (2520 Type) Opamp Kits and DIY Parts Galore!!!
Due to supply chain problems I am temporally using BC550C ON TAPE instead
of bulk. These are well marked in the little kit bags in the kit.
Do not mix these up with the BC560C which are on tape and loose in the kit
when assembling "gar" DOA kits that Jeff sells
GARY
Yes.
VAT+Customs+Shipping.
You must add Custom and VAT (in Germany circa 22%) to the overall price.
So if your order from CAPI for like 350$ with shipping, then add circa 22%.
1/1/2013 Update:
-BB2521 IC-Discrete hybrid opamp kits added to the store. http://classicapi.com/catalog/index.php?cPath=71_183
-One time batch of NOS Philips NE5534N's added to the store along with TI's LME49710's http://classicapi.com/catalog/index.php?cPath=71_73
2/2/2013 Update:
-EA2622's are back in stock http://classicapi.com/catalog/product_info.php?products_id=80
5/19/2013 Update:
-Elma-Neve-Marconi knobs have been added to the store http://classicapi.com/catalog/index.php?cPath=23_184
-2 custom Elma 04 series rotary switches have been added to the store http://classicapi.com/catalog/index.php?cPath=51_133
7/6/2013 Update:
-New 15 and 18 pin card edge adapters for 500 and 51x prototyping have been added to the store. http://classicapi.com/catalog/index.php?cPath=87_88
1/8/2014 Update:
-553F EQ kits have been added to the store. http://classicapi.com/catalog/product_info.php?cPath=22_117_119_170&products_id=417
-500/51x Extension Jigs are now in stock http://classicapi.com/catalog/index.php?cPath=22_117_185
-Small one time batch of dual 10k pan pots have been listed http://classicapi.com/catalog/product_info.php?cPath=50_131&products_id=422
8/17/2014 Update:
Custom Crimson Ribbon Mic upgrade transformers! I added two variations of these some time ago but forgot to mention it here.....
-The 1:35 version. http://classicapi.com/catalog/product_info.php?cPath=21_186&products_id=414
-The 1:40 version. http://classicapi.com/catalog/product_info.php?cPath=21_186&products_id=415
10/11/2014 Update:
-VF600 discrete opamp blocks manufactured by Steve Firlotte of Inward Connections can now be purchased at the store http://classicapi.com/catalog/product_info.php?cPath=71_72&products_id=429
11/1/2014 Update:
-Fluted-Skirted Neve Presence knobs from Elma are now available at the store
http://classicapi.com/catalog/product_info.php?cPath=23_184&products_id=430
3/15/2015 Update:
-New Litz wire version of the 2503 has been added to the store
http://classicapi.com/catalog/product_info.php?products_id=437-New 2-Stage utility line amp cards have been added to the store
http://classicapi.com/catalog/product_info.php?products_id=438
5/3/2015 Update:
-4 new potentiometers added to the store. 2 different panpots as well as some other goodies!!
http://classicapi.com/catalog/index.php?cPath=50_131
6/17/2015 Update:
-Litz wire 2623-1's have been added to the store
http://classicapi.com/catalog/product_info.php?products_id=450
Hello Jeff ,
check links ,
seem that do not work properly ,
cheers
I went to look for 10 packs of the CA 0252 on the site, but none available right now. I like how convenient they are to build a bunch of them, rather than sorting the single packs. Is it possible to get them this way again/soon?
Yes but they are at least a month out. We have to send transistors out to be put on tape. Its a small process.
CA-0252 10-packs are back in stock.
We also still have about ten 511 rack kits left from our last batch.
Hi Jeff,
This is a copy of the email I sent directly to CAPI... I'm not sure which emails/forums are monitored. Thanks for the 511 kits. Everything good but I'm missing 2 short backplates (the 3 channel backplates with the printing on one side). Can I get those shipped out? Also, are there a few spares of the Phillips M3 screws in the kit? I stripped 2 of them even though I use a German Wiha screwdriver and adequate force. The screws are just real soft metal. If the kit has just enough for the build can you please throw in a few extras with the backplates... if there are spares in the kit we are good.
Thanks! My order number is 31576
Hi Jeff,
Yeah I got it, replied and sent the 2 missing rear panels. Sorry for the error.
Hi Jeff,
I sent you an email on 8/19 and DM'd here a few days later re: a few missing or damaged parts from order # 31621. Hope to hear from you, thanks.
Hi Jeff,
Sorry we were off last week and slammed up to that point. Can you resend the email? I don't really have the bandwidth for DM's here.
NOTICE OF PART CHANGE
Had to happen sometime... The pnp BC560C has been out of production
for some time now and my current supply of NOS Fairchild BC560Cs
that I have been using for last 3 years is running very low. I will be using
the remainder of my supply for only for the matched pnp input pairs for the
garOA10 and gar918.
I knew this day was coming so I have auditioned many possibilities.
From now on I will only be using..
BC557C mouser # 637-BC557C in the following positions...
gar2520 Q6, Q9.
gar1731 Q3, Q4
garAM10 Q1,Q5,Q6,Q7
garOA10 Q2, Q3, Q5, Q7, Q9
gar918 Q3, Q4
Note that these are all on tape and will just drop in place to the silk
just like the original BC560C
Gary
