Just had this amp back for the second time in six months for repair .
Twice now its blown in4007 ht rectifier diodes .
Theres two diodes in series with each leg of a centre tapped secondary to make the Ht.
The guy that uses it is young and Im wondering if he's not using the standby switch and thats whats causing the diodes to blow .
Ive swapped out the power tubes now as well as replacing the diodes ,just in case there was some kind of intermittant short in one of the power tubes.
Its a few years old now the amp ,but looks like it hasnt got that much road use on it ,when it works it works great and sounds good then for no apparent reason it just dies ,the blown diodes taking out the mains fuse .
If anyone has seen similar trouble from one of these amps Id be greatfull for any advice .
Thanks again,
Thanks again,
