midwayfair
I picked up a Cinemag 4:1 mic output transformer with a center tap on the microphone's side for phantom power.
I can't think of a mic schematic off the top of my head that uses a center tap so I'm not sure how I'd use this, but I'm familiar with the pretty standard pair of 2k2 (or whatever) like in the U87 that go between the hot and cold and make a single DC point. If I'm using an existing layout with that setup, can I simply hook the center tap up where the junction of those two resistors go, or do I need to add a resistor between the transformer lead and that spot?
Side question: 4:1 is a little bit of an unusual ratio. Lower output than the 2:1 in the emitter follower circuits (which I'm fine with) and too low a ratio to use in a regular 87 or 84 style circuit. Anyone have a suggestion for other circuits for me to consider using with this transformer? Or can I maybe get enough current with a center tap to get down to 3k3 output impedance of a single JFET circuit?
