[I pulled all the cards] -- WELL-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L-L.....I -- may -- be able to help you out here, but.....you will need to first provide me with some information. Several years ago on this forum, I was contacted by a member who had purchased an original 1974 API mixing console that he wanted to restore. Upon him learning of me on this forum and my background in designing electronic equipment, he then physically mailed me one each of each different PCB within his console so I could go through the process to "Reverse-Engineer" each circuit card. My task was to create all new PCB-designs with GERBER files so he could then have all "New/Old" PCB's made. And, even though after I reviewed the original PCB's and I could easily see many areas of PCB-layout improvements, he wanted all of this PCB's to be -- EXACTLY THE SAME -- as the original circuit cards. I guess he was afraid of losing any of the "Audio Magic Mojo" that his console possessed!!!
In any case, I carefully made multitudes of mechanical measurements of the original boards and created all new PCB-designs using my CAD-software. Once I had all of that, it was then easy enough to ZIP-up all of his PCB fabrication files and e-mail them to him. From there, all it took was for him to buy all of the electronic components and send my GERBER and N/C Drill data files to whatever PCB fabrication shop that he chose and put everything together. And, as a side-note.....I have also done the same thing when I was once contacted by a huge aerospace company who had contacted me to "Reverse-Engineer" a PCB of theirs that had been originally designed in 1979 and they no longer had the manual hand-taped artwork to fabricate new PCB's. So, in this instance, not only did I "Reverse-Engineer" this 40+ year-old PCB-design, but the aerospace company also wanted me to update the design from using old "Thru-Hole" components to modern "Surface-Mount" components. So, that was easy enough for me to do when I created the schematic and inputted "Surface-Mount" PCB-footprints for all of the parts. EZ -- PZ!!!.....
Similar to what I just mentioned above, if you can physically mail me one each of your Spectra-Sonics PCB's, I can go through and obtain all of the information that I need to accurately recreate each of the PCB's. In addition, since you had also mentioned that you would like to have your own individually styled PCB, if you can clearly sketch-out what the dimensions would be, where and what size any mounting holes are and anything else that "your heart desires", I could incorporate all of your requirements into a new custom-designed PCB!!! NO BIG DEAL!!!..... But, I physically need to have the original Spectra-Sonics PCB's in my hands first. Once I am done "Reverse-Engineering" them, I'll mail them back to you. How's that?
Of course.....you have no idea who I am or even if I am capable of doing what I just wrote. So.....the attached PDF file should easily answer that for you. Should you be interested in moving forward.....I'll help out as much as I can, OK???.....
Just sayin'.....
Former Audio Engineer
Former Studio Recording Engineer
Former Sound System Design Engineer
Once worked with one of the largest concert sound-reinforcement companies in the world
Former "LIVE" Recording Engineer
Former "Other Stuff" Dude.....
Currently "Too Old" to do audio work, so now focused on "Equipment Design Engineering" projects
