As I understand it ( I THINK), if you have a say, 120V AC input to primary transformer with a centre tap...
You will have (1:1 in this case) 60V AC on each leg of the secondary and the centre tap seems to go to ground in alot of schematics I have seen (power supplies). I understand this puts the secondary 60V above ground potential. Is this to limit noise and hash? Am I on the totally wrong path?
Seeing bridge rectifiers are the go mostly these days, what are some other uses of Centre tapped transformers? thanks.
