Kingston said:
another GSSL clone it seems. with some mods. some easier than others.
2. It has a switchable dual sidechain ie. "turbo" mode (this is closer to how a real SSL 4000 series bus comp behaves). some call it oxford mode.
Are you talking about the Chameleon, as pictured in the above 'guts' photo?
If so, there's no turbo mode... To do a 'turbo' requires a total of FOUR VCAs; one for each chanel and one for each channel sidechain. -The Chameleon has three VCAs, -same as a GSSL with NO turbo.
My last build used a demounted rectifier and a C/R/C/R/C reservoir board, which removed the ripple and improved noise significantly (a measured 17dB noise improvement). -Other than that, I wasn't able to noticeably or measurably improve upon the 7815/7915 regulator combination, so I'd take slight issue that there are improvements to be made in that area.
The chameleon is DEFINITELY developed from the GSSL. -You can see it in the layout, and how closely it mimics the GSSL. -Jakob's little 'module' for replacing the can VCAs is essentially transplanted right into the layout. The TL074 and TL072 remain unchanged (instead of 3xTL072's for example... and the division between the 072 and the 074 looks the same... the ORIGINAL SSL version did not use ANY 074's, so that's another big clue!)
Another clue is the apparent use of 5532's for the outputs and 5534's for the inputs... the original SSL used 5532's ONLY, with no 5532's anywhere.
So I can only conclude that it's plainly "inspired" by (i.e. a pretty much direct copy of) the GSSL, which has been 'expanded' by the inclusion of the sidechain filter. -It cannot do 'turbo' mode, which means that it can't do what the real SSL does. -Looking at the expat audio YouTube demonstration, should make it pretty clear that you NEED the fourth VCA in order to do what the real SSL buss compressor does.
Improvements: -The power supply looks better, and the sidechain filter gives options. -However, the sidechain filter was only EVER developed to address the GSSL's tendency to 'overcompress' low-frequency, center-panned instruments. -the original SSL buss compressor
NEVER needed this, because it DIDN'T 'suffer' from the same traits... As a result, this further reinforces my view that this is a copy of a GSSL including the attempt to reduce the inherent "misbehavior", and a further improvement in supply noise reduction.
A GSSL with a sidechain filter will do the same thing, and if you include the remote bridge rectifier and C/R/C/R/C mod (which is a $5 mod) then you will match its performance. -The apparent choice of inexpensive ceramic capacitors suggests that there have been some corners cut in terms of component cost.
That's by full "analysis"... I do think that the conversation is better held in the forum ina thread rather than over PMs or emails, so that everyone can share in what's discussed.
Keith
