hi all,
i have a TAC Scorpion II, 30-4-8-2 Configuration.
i am part way through re-capping the channels, 25 completed so far.
everything is working on the desk, with one exception.
on one of the channel input (S1101) boards, the mute led is behaving strangely,
the channel passes audio fine,
eq works,
sends fine,
buss sends fine,
the AFL engages,
AFL led works,
AFL signal is good,
engage mute,
mute works,
mute led is so faint as to not be lit.
then engaging AFL,
takes out both the led's,
to very faint.
i have already re-capped this channel,
the issue was there both before & after the re-capping,
i have also swapped the three transistors with new ones, just to see if that could solve it.
i have measured R65 and it is fine.
i also re-floated a heap of random solder joints on this board.
can anyone help me figure this out, or at least suggest a way i can pin it down.
best
pb
eq works,
sends fine,
buss sends fine,
the AFL engages,
AFL led works,
AFL signal is good,
engage mute,
mute works,
then engaging AFL,
to very faint.
best
pb
