Ive got a bunch of the Lidl 20v tools and batteries ,
there not super heavy duty ,but still very good value for the money .
Beware though , I purchased one of their mains powered angle grinders a while back ,
as soon as I put the unit under any kind of load the commutator and brushes turn into a lightening storm , the first one I returned , then a newer model came on the shelves , bought one of those ,
same thing , even worse the unit has speed regulation , that tends to go to full RPM randomly while in use ,
I would have assumed these units having metal exposed on the housing are required to have a three wire mains cable , it has a proper three pin plug with PE , but only two wires in the cable , which I discovered when the cable frayed where it enters the tool .
These things are dangerous , thats for sure , if it turns out it should have protective earth and doesnt they have a very serious safety problem that could land them in hot water if someone got hurt .
I wont interact online with Lidl to get a return code , but I think its only right to try and warn the manager of the store these units are potentially dangerous .
What I'll do is call into the local tool hire place and check how the reputable brands of grinder are wired .
A quick search shows this ,
![mixer grinder circuit diagram.png mixer grinder circuit diagram.png](https://cdn.imagearchive.com/groupdiy/data/attachments/79/79926-219349747577bd114fb8cc7132610d63.jpg)
