forzasalva
Member
- Joined
- Sep 28, 2010
- Messages
- 16
Hello folks,
I hope you're doing fine in these crazy times.
It's now 4 years that I regularly purchase (single-sided) Chinese CK12 capsules from a few Chinese suppliers (the ones with the blue plastic and the yellow adhesive tape).
They always worked fine, as long as I put some isolation on the backplate cable to avoid the exposure to humidity and moisture.
Now since May I noticed some very serious problems with their newer batches.
8 of 10 capsules simply won't work. The output is very low and sometimes very noisy and distorted.
That was never the case with the old batch.
I tried isolating the backplate cable with some acrylic lacquer (as I always did) - nothing
I tried putting a spacer between the backplate and the cable - nothing
I tried cleaning all contacts (front and backplate) since they put some strange red sticky stuff on it (not loctite) - nothing
I also tried adding some extra space between the backplate and the membrane - also nothing.
Sometimes it helps to swap the backplates. I then just use the other backplate with the membrane. But with that new batch this also doesn't help.
I tried all threaded holes in the backplate (with the backplate cable), but still nothing.
There always is a measurable capacitance of 10-14nF (which is high, but the old capsules still worked).
One thing I noticed is, that when I remove the yellow adhesive tape the capsules will work as long as I don't speak into the microphone. As soon as I speak into the microphone the output drops significantly and comes back after 1 minute.
What could be the problem with those capsules?
Thanks a lot for your help
forza
forza
