CL-1B - History ?
FerrariT
Minnesota
Correct me if im wrong but isn't the CL-1B based upon the La2a, Was it not made because the la2a was out of production?
If this is a modified clone what was changed?
I apologize if im wrong, I've no clue just shooting in the dark I suppose.
I've never heard one, but people describe them as clear and smooth or transparent [but no thin].
Anyways whenever they are brought up, well the la2a goes hand in hand like Tom & Jerry!
Just curious.
An all-tube optical compressor that can add just the right touch of magic to anything from delicate vocals to slammin' drums.
The Tube-Tech CL 1B compressor differs from many other compressors, in that the gain reduction element is made from a non-semiconductor element, which in itself has a very low harmonic distortion and none of the non-linearity problems involved when using most semiconductor elements. Furthermore there is no long-term degradation of the element thus giving it almost infinite life. This signal processor is placed after the input-transformer of the compressor and followed by an all tube-based amplifier with a gain of 0dB to +30 dB. Thus the signal is not fed through any semiconductor circuitry on its way to the output.
The amplifier consists of two tubes (valves) in push-pull configuration (one ECC 83 as the pre-amp and phase splitter, and one ECC 82 as the output stage), and an output transformer. The power supply for the preamp and phase splitter are stabilized and the heaters of both tubes (valves) are fed with a stabilized DC voltage. The whole amplifier (including input and output transformer) and the power supplies are placed on one PC-board. Both input and output are balanced (600 Ohms) and fully floating. The in/out key switches the compressor in and out without clicks.
Tube-Tech CL 1B Compressor Features:
    * Non-degrading optical gain reduction element
    * All-tube amplification
    * Linkable for stereo applications - up to ten units
    * Sidechain
    * VU-meters showing output or compression
    * Fix/Man mode allows automatic program-dependent operation
    * Conductive plastic potentiometers
    * Gold plated switches
    * Clickless bypass relay
    * Analog Outputs XLR
    * Analog Inputs XLR
Tube-Tech CL 1B Compressor Specifications:
    * Frequency-response: 5 Hz - 60 kHz +0/-3 dB
    * Distortion (THD) (40 Hz): 0 dBU: < 0.15 %, 10 dBU: < 0.15 %, maximum output (1 % THD): +26,0 Dbu, maximum input (1 % THD): +21,0 dBU
    * Noise: Gain = 0 dB: -80,0 dBU (Unweighted) -70,0 dBU (CCIR 468-3); Gain = +10 dB: -80,0 dBU (Unweighted) -70,0 dBU (CCIR 468-3)
    * Input impedance: 600 Ohms
    * Output impedance: < 60 Ohms
    * Compression Ratio (cont. var.): 2:1 to 10:1
    * Threshold (cont. var.): -40 dBU to +20 DBU
    * Gain (cont. var.): off to +30 dB
    * Tracking between interconnected compressors: (0 to 30 dB compression): < +/- 1 dB
