Neumann Vintage U87 Clone : Build Thread.
Exact. @Jmaffei ask in the thread I posted previously.
@Khron explained very well.
I hope the extra fees don't cost me more than the capsules 😀
We just love paying taxes in the UK! Thankfully these amazing looking capsules are reasonably priced even with the tax and imports. If only I'd known when I made my Fet47 a couple of years ago!
The k87 capsules are about 2 weeks out right now. We're finishing enough for everybody plus I'm going to add some single diaphragm ones to use up more of the Overstock plates. Yes, cardioid Omni just would have slightly unbalanced figure 8. If your use of Figure 8 is not critical, you can comfortably buy the B stock ones. My shop software doesn't allow for Dynamic tax based on shipping option for some reason? Seems like an oversight. So if you select UK shipping DDP the tax is in the shipping charge instead but it will be prepaid, don't worry
Thanks so much for clearing this up! I didn't see the UK shipping option before, that makes a lot more sense now.
If i were to put in an order with various capsules and transformers, would you wait until you had everything in my order ready before you ship? I only ask because I'm looking at a list of items but I wouldn't want one of them to delay the whole order. And obviously shipping multiple times will be expensive for me.
So far I'd be looking to order this:
1 x UTM 0547F
1x K47 (Cardioid) < Why does the shop only allow me to add 2 of these at a time, I can't seem to add only 1?
2-6 x UTM 0587
2-6 x K87 (Cardioid/ Omni)
(finalising a group buy with friends, so not sure on numbers just yet)
Honestly, finding this thread and your capsules has got me fully back into the mic-building fever, thank you!
keep in mind "economy shipping ddp" is evri so it depends on how good your local evri delivery drivers are. if they've given you trouble in the past, it's better to pick dhl ddp
i'll handle it however you put in the order notes. the shipping is cheap, so i don't mind splitting it up. as for the k47 cardioid issue, i think it's just a matter of the cart not updating and you already had one in there. just set the correct quantities in the cart. also, don't use this thread for this.
another issue is that cardioid/omni capsules are qc fails, so they have limited quantity and are first come, first serve. i usually disable the listing when we don't have any, but i was at namm when we ran out. you won't be able to buy a ton of these at any given time.
Can someone help me with the correct wiring for a UTM0587? how do the color codes relate to whats marked on the board?
Also there is a yellow wire I dont know about on the UTM.
Here is the data sheet. Has anyone else used one with this build?
    170.5 KB
Hi @theom
There have been several revisions of the U87i and different PCB versions
Post here the schematic you use and clear pictures of the PCB
Is the Zener diode 24v or 33v?
The yellow wire connects to GND, being the shield between primary and secondary, as @Khron said, but in some schematics it is not drawn, it is understood.
*Edit: You are most likely using one of the schemes below
    215.1 KB
    321.9 KB
@theom
Connect UTM 0587 as in the picture.
YEL connects together with BLK.
If the D-87 will not be in phase with any standard microphone (condenser or dynamic), then you must reverse the VIO and GRN wires of the transformer.
    233.4 KB
    112.8 KB
    262.3 KB
@theom
Thank you so much.
This is exactly what I needed.
I always question how the schematic relates to the circuit boards.
This forum is a fantastic resource for learning and the way it fosters interest in DIY.
Bravo!
Next Question:
Trimmer pot pinout:
Solder pins 1 and 2
Leave pin 3 open (cut it so it doesnt touch the pad on the board)?
And on the board, which of the 3 pads are 1 and 2?
Again, Many thanks
Theo
Next Question:
Trimmer pot pinout:
Solder pins 1 and 2
Again, Many thanks
Theo
Hi Theo!
Connect as in the picture.
You must connect pins 2 and 3 according to your notation. Here the resistance between Source and GND is adjusted. With pin 1 you can do whatever you want. Don't cut it. If you leave the adjustable resistor permanently in the circuit after BIAS, then solder pin 1 as a precaution against interruption and as an additional GND connection.
You may decide to replace the variable resistor at the end with a fixed resistor (or more, in series/parallel) of the appropriate value.
    239.7 KB
    127.1 KB
    897.5 KB
Mic is working!
But I must have something wrong.
needs 50dB of gain to get anything usable, and has a high noise floor which would make sense.
I will start looking for a incorrect value component,
Pattern switching and pad are working as expected.
It's a journey,
Mic is working!
It's a journey,
Hi @theom !
I'm glad your adventurous trip is rewarding. But it's not over yet. For optimal operation, you must adjust the BIAS of the jFET, from the trimpot, @Khron also told you, so you should measure about 10.5...11.5v on the Drain compared to GND, if you used a selected jFET with a recommended Idss in the 4...10mA range. You do the fine tuning more carefully according to a correct method, with accuracy, but according to personal preferences.
You should be aware that this vintage U87 version offers a lower output level than modern microphones, for example compared to the U87AI it can be about 10dB quieter.
The high self-noise can be caused by the fact that you did not clean the PCBs very well of residues, especially in the very high impedance area, input/switches PCBs
Also, if the jFET is not BIASed correctly and does not have enough gain, you have forced the preamp and obtained exaggerated noise.
Edit:
We recommended that you carefully read the thread for all these details. All these aspects have been analyzed and discussed countless times.
Mic is working!
It's a journey,
I guess you might've gotten everything soldered up, but sounds like you expected this to be some "fire & forget" type deal..? So you haven't bothered going through the entire build guide, to the end?
https://www.vintagemicrophonepcbkit.com/Neumann U87 Build.htm (spoilers - it's in the first post in this thread)
