[quote author="SSLtech"]It's all about cheap, not about good.
Keith[/quote]
Yes, and soon in every theatre, sorry,
amp near you (if not already).
Did you think you can buy a 5.1 home-cinema system for some small change and have the manufacturer still adding decent heatsinking etc to the box ? Efficiency has to go up, material costs down and as long as you don't replace the cardboard speakers that came with the set you won't ever find out about the uncoolness of that cool class-D amp.
Don't blame the people making class-D amps, but blame the consumer that wants to have it all - but needs to have it for cheap.
And no !
Class D can be mighty fine though; read this (on the website of a respected amp maker, article by Bruno Putzeys who knows where he's talking about):
http://www.bryston.ca/newsletters/74_files/vol7is4.html
So please don't leave this thread with the idea that class-D is always inferior. There are many tastes in or ways to class-D, just as there are in class A & B.
So then why 'risk it' when you can have a fine A- or AB-amp ? Each class has its pros & cons. I don't want to sound like an ad, but it'd be hard to deny several advantages of class-D (
if the sound is still OK of course, a debate we better leave for another time and I rather don't join).
Example: let's say for now that
these line arrays are active, so with the power stages & supplies inside. Imagine the difference in weight for stuff like that. Less heatsinking required because of the higher efficiency. And since less power lost the supply can be smaller & therefore lighter.
Regards,
Peter
