walter
If these are truly a cheap, and not about good, near impossible to repair device, they may end up in some Behringer equipment, and I will get ahold of 'em, if I haven't already. btw, I get the E-spam from Hearst.
Mlewis said:[quote author="bobkatz"]
I'll let you know how they sound compared to my $6000 Class A Pass X250!
A bit OT, but anybody knows how much class A these things really are? 1200 W in pure class A looks rather unrealistic.Class A Pass amps.
The amplifier idles at about 270 watts.
The X250 has a power transformer rated at 1200 watts, continuous duty. Under actual
conditions in the amplifier, it will do about 1800 watts for short duration.
The X250 has 20 computer grade capacitors at 10,000 uF and 50 volts each. These are used
to create the unregulated output stage rails at plus and minus 47 volts at 20 amps.
All the power transistors in the product are power Mosfets, actually Hexfets from International
Rectifier and Harris. These are hyper-matched parts, with gate voltages matched to 0.5% and
all devices taken from the same lot codes (made on the same wafer). The speed and noise
critical gain devices in the front end, (that is to say the actual balanced pair of transistors) are
ultra low noise and distortion matched JFETs having a low (.02 S) transconductance figure.
The JFETs are made on the same substrate for prefect matching.
The X250 has 32 output Mosfet power transistors in TO-3 metal packages. The output stages
can sustain transients of about 6,000 watts, but are not allowed to dissipate more than 1000
watts for any instant, even into a dead short.
For these amplifiers this is about 600 watts worth. This is not pure Class A
operation in the context of 1000 watts output, but it has proven to be the appropriate amount.
I have a question about power supplies for a class D. Is a switching amp "hard" on the power supply caps and sensitive to the ESR DF inductance etc?
