pucho812
oh no...I've called his number twice, it appears to be disconnected or non-attended. Email sent requesting return of my property :/
Taz!Hi Rohan,
I'm coming in very late on this thread. Sorry about that.
It came to my attention whilst I was on vacation, I just got back.
Anyways, I am the designer for Trident at PMI Audio and also the guy who redesigned the Trident Hi-Lo 500 unit. It was the tracking filter portion of the Expounder which was updated and improved. It was Allan Bradford who worked at CLM Dynamics who designed the initial unit and I don't believe it was a patented design, I may be wrong.
Anyways, since CLM Dynamics was purchased by PMI audio they own all rights to the design.
I am surprised that you did not get any help from PMI Audio service. I believe they probably responded as such because we do not carry any of the components any more for that design and as such would not take on a repair. But in the interest of you trying to repair the unit yourself we can provide documentation, under certain conditions which we can discuss.
If you want to private message me, I have access to all the old schematics you require. I guess now we have to see if you can get your unit returned :-(
Let me know if you are interested and if you get your unit back.
Taz.
Yo Taz, hows it going...?Hi Rohan,
Taz.
noise might be as simple as an opamp or might need a recap.Hi All,
Following this thread with interest, as I own an Expounder with an excessively noisy channel.
@Taz: Thanks for chiming in, I sent you a private conversation.
Best, Rogy
Hi JR,Yo Taz, hows it going...?
you ever see the move a bronx tale? maybe your getting off easy in that you won't have to see him again.The 'audio pro' nutter telephoned this afternoon. 12min 47sec of nonsense.
Additional to the money I sent with my DB500S last December (for zero result), he wants $US60 to ship it back - with the transformer and power supply board removed.
It is worth another sixty bucks to be able to block the lunatic's number.
Getting my Expounder back will also be nice.
Taz - moving forward finally!
Very old thread but, anyone have a schematics for a CLM Expounder ? Or can recommend someone to repairHi Rohan,
Taz.
What seems to be the issue?Very old thread but, anyone have a schematics for a CLM Expounder ? Or can recommend someone to repair
Thank ken
The unit is passing siginal dry signal only.What seems to be the issue?
Can you recommend someone to do this ?With any unit and not having a schematic,
There are some things to check.
1.psu is outputting the correct voltage
2.capacitors. Those units run warm so a recap is in order. You don’t need a schematic for that, just test the caps and see which are bad and replace.
Helps to know where you reside to come up with that answer.Can you recommend someone to do this ?
At my age I’m not steady enough soldering anymore
I’m in Oklahoma US . I’ve reached out to a couple guy’s around here , no one will even look at it without schematics .Helps to know where you reside to come up with that answer.
@Brian RothI’m in Oklahoma US . I’ve reached out to a couple guy’s around here , no one will even look at it without schematics .
It’s basically worthless as it is .
Brian was one of the tech’s I’ve already contacted
