Cohen Preamp Servos
Dylan W
Boston
I was comparing a few versions of the Seventh Circle Audio C84 (based on the Cohen topology) and noticed a difference between the DC servos.
Just to start with the first stage:
In the attached schematic (v1.6), a single inverting first-stage servo takes input from R27/28 and spits out the correction in front of the matched input transistors, through R5/6.
In the schematic linked here (v2.0), the first stage has two servos: an inverting servo that takes input through R29/30 but feeds a second pair of matched transistors, and a second, differential servo that only feeds the "-" input terminal through a 100K resistor, while the "+" input terminal goes to ground through another 100K resistor.
What's the difference? What are the different servos doing?
(Am I correct in guessing that, in v1.6, the single servo correcting for common mode DC, while in v2.0, the differential servo is handling common mode DC and the inverting servo/transistor array is correcting DC across the gain switch?)
  • c84_sch.pdf
in the link schemo ]
U3b is sevro'ing the common mode (A+B)  DC output voltage to 0V dc
U3a servo's the net differential voltage (A-B) to be 0Vdc.
FWIW they could accomplish the same thing by servo'ing each output separately to be 0vdc
Sorry I don't see an attached schemo.
Ok, I think that makes sense. In the v1.6 scheme (below), why does U2a inject through R5/6?
In the v2.0 scheme, why does each side go through paralleled transistors to the emitter of the input transistor?
Should be attached at the bottom of my first post. Here's a dropbox link.
Also, in v1.6, there's another servo around the balanced floating output stage and the Jung buffers, with some kind of cross coupled feedback (?) through R46/57.
V2.0 has that cross-coupled thing again through R49/61, but it's AC coupled.
