Collins transformer experimental build in (hacked) C12 style.
pinchemotherloaf
West Coast, USA
Found this big Collins transformer 16:1 and wanted to see how it sounds in a (hacked) c12 style design. Typical bias to capsule and grid with coupling cap and 6072 tube. Cheap capsule. And plenty of that DSL cross-connect wire! The sound is not what I expected: It is hot loud and bright but interesting, maybe acceptable at lower levels. I was expecting something darker, but.. it's just an experimental microphone!
Is that rated for 10mA DC on the primary? Wouldn't that mean it could be placed (possibly with a series resistor) right on the tube plate, foregoing the need for a coupling capacitor?
Just a stupid thought...
As far as I can see this is a 10k to 600R transformer, so it is 4:1. This will result in an impedance mismatch, thus the weak bass and the high output level.
I can't read it correctly, what is the bandwidth written on the transformer in Hz (cycles)?
It indicates 100-10kc but the fellow I bought it from said he tested them to up to 30kc +/- 2dB
That would explain the high output and weak bass from the ratio, thanks.
Maybe you can compensate the problem with a tube that can deliver more current and has a lower internal resistance, like an ECC88 or similar. Are you using both triodes of your tube?
This will depend heavily on the properties of the source of the signal, you need to test for this in your circuit.
May i ask how did you get to this conclusion knowing only dcr of the transformer?
Yes, of course. Usually, as far as I know, transformer manufacturers specify impedances, not the resistive value of the windings, on their casings.
    292.5 KB
    765.9 KB
    135.3 KB
I also had thought about the use of gapped transformers in microphones and why there is none I know of where it is used.
Especially because the current is quite small most of the time so the gap doesn't have to be so big.
Any reason why no mic use gapped transformers?
@pinchemotherloaf don't you want to try it for us all? Ditch that cap and tell us how it sounds :D
OK I'll try in out!
