compressors per channel
yes it's this one
sorry I don't point any schemo link guessing you'r a well documented guy
Nominal is -15dBu for this comp, internal level at insert, console setup @ +8dBu line level
so the clock noise should be around -95dBu, 103dB below line level if I'm right
My overall noise floor is way over that with all channel open, outboard insert and fx at send/return  :)
Best
Zam
I would like to have in each channel of a console an analog emulation of this compressor:
No ratio control, no release control?
I think a custom implementation of THAT chips combining AN  (Application Notes) 115 & 113 would fit the bill.
http://www.thatcorp.com/datashts/dn115.pdf
http://www.thatcorp.com/datashts/dn113.pdf
Whoops said:
Yes,
Great isn't it?
It just works  really well.
It would be better if it didn't even had the attack knob
Then you could use the basic implementation of the THAT audio engine 4301. Fig 2 of http://www.thatcorp.com/datashts/dn107.pdf, with the addition of a simplified meter as in http://www.thatcorp.com/datashts/dn132.pdf
