rock soderstrom
Tour de France
I usually run my audio and DC heater grounds separately in my tube preamps. The heater is then connected to the HT+ ground at one point, usually at the output of the HT+ power supply, my central ground point, which is connected to the chassis and protective earth.
I am designing a PCB at the moment and wonder if it would be disadvantageous to consider the DC heater ground and the audio ground as one?
I am building with steel tubes, the pin 1 of these I also connect to audio ground, it would be very space saving to connect the heater ground to this as well.
Is there anything wrong doing it this way with a well filtered regulated heater voltage?
