Hello,
Apologies in advance for the possibly naive question - I've searched but haven't found anything specific.
I'm starting to design a project that will have a main board and a number of child boards, which will be attached perpendicularly to the main board. The boards will not need to be unplugged/re-plugged frequently once built. Using right angle pin headers on the child boards and sockets on the main board would be a cheap & easy way to connect them. Will this likely be good enough as mechanical support for the child boards? The child boards will be reasonably small and light.
I've seen quite a few examples that use pin headers for connection where the boards are parallel - arduinos, for example - but I can't think of seeing ones where they're perpendicular. Maybe it's common and I just don't get out enough...
Thanks in advance for any tips!
