I am repairing an old measuring instrument. It has a complex discrete circuit that buffers 5 MHz square wave with low output impedance. The buffer is broken and there is no documentation available (it is not a factory made device and the designer lives in rest-home).
I replaced the whole buffer board with four 74AC540 gates in parallel. Each gate provides up to 24mA output current according to the datasheet. It works surprisingly well. Perfect square wave output dispite the low impedance load. It actually works so well that I came suspicious...
Are there any disadvantages in connecting the gates in parallel? I understand that if timing is not perfect, quite large currents can flow between the outputs. But I am using adjacent gates in the same chip, tied together with very short traces.
In have seen designs with a small series resistance in all outputs, but in this case it would increase output impedance too much.
74AC540 datasheet:
http://www.ti.com/lit/gpn/cd74ac540
74AC540 datasheet:
