Semiconductor crosspoint switch array? Unbalancing/balancing circuitry? Nein, danke.
In the real world, we have to use connectors. IMHO, XLRs are our best choice for low signal levels. After decades working with this, TT bays (even from reputable companies like Switchcraft, ADC, etc) are totally unreliable for mic levels.
Sort of like a souped up Kramer?Semiconductor crosspoint switch array?
According to IEC 61938:2018-10, the short-circuit current must be 7mA. If the 6800 Ohm resistors from the 48 VDC supply do not tolerate this current but burn, the circuit does not conform to the standard. The cause of the burning is that 1/4 watt resistors are used in cheap devices. The short circuit current is 1/3 watt though, so a decent circuit should have at least 1/2 watt resistors.The main issue with microphone jack patchbays is the short that happens each time a cord is inserted or disconnected, particularly when phantom power is applied.
Although most console/preamp/mic manufacturers have implemented the necessary protection circuitry, there are still many pieces of equipment that don't have them.
The consequences can range from straight non-function to progressive loss of performance.
XLR, relay or Ghielmetti patchbays are immune to this problem.
The issue is not with resistors burning.According to IEC 61938:2018-10, the short-circuit current must be 7mA. If the 6800 Ohm resistors from the 48 VDC supply do not tolerate this current but burn, the circuit does not conform to the standard. The cause of the burning is that 1/4 watt resistors are used in cheap devices. The short circuit current is 1/3 watt though, so a decent circuit should have at least 1/2 watt resistors.
Do you have any evidence for this statement? I know that's been said time and time again, but I've never found any hard evidence for it.Also, the non-simultaneous connection can be dangerous for ribbon microphones in the case of older consoles that have P48 always on all channels
I've in and out of pro studios since early/mid 70's (studio with a desk and a 8/16 recorder). Phantom power was new, especially to me. An older mentor told me to keep phantom off when patching. He gave me a demo with a Shure 57 while he was intentionally doing patching screw ups; I could clearly HEAR the element making clicking noises.Do you have any evidence for this statement? I know that's been said time and time again, but I've never found any hard evidence for it.
Thanks for taking the trouble to explain the problem. Very enlightening.It is important to analyze the issue.
Regarding microphone connection, the problem occurs during phase 2 of connection, where the tip of the jack connects with a phantom-powered point and the ring is still grounded.
Depending on the type of preamp the current can be significant.
If steady-state only was considered, the power dissipation would be limited by the 6.8k phantom geed resistors, to a very small level. 7mA into 200 ohms results in less than 10 microwatt, which is without any danger.
However the pulse of 48V may result in an instant peak power of a few watts for a duration of 20-30 milliseconds, which is enough to produce a loud click.
It is usually harmless to transformer output mics and dynamic mics, but can result in large displacement of the diaphragm in ribbon mics, which distends the ribbon and results in loss of level and frequency response.
Transformerless mics can also suffer. The most pernicious way is when the output transistors go into Zener mode, which often degrades them in a subtle (and cumulative) way, so the
re's no obvious sign of problems.
Although there are more cases when patching hot mics results in no damage than cases otherwise, it is still good practice to avoid doing it.
Yes, it's the typical recommanded protection for this type of circuit.At TI I found the schematic of a microphone amplifier front end, which nicely shows what measures should be taken to avoid damaging the first amplifier stage. (Scroll down to the last circuit diagram and its explanation.)
https://e2e.ti.com/support/amplifie...forum/665925/ina163-regarding-circuit-diagram
I was able to download the papers you mentioned about "The 48 Volt Phantom Menace Returns", they can be found in the AES E-Library
