I have been messing with more bands and have got a three band in the simulator with a 50Hz inductor LF, a CAPS MF and a 10kHz inductor HF.
First thing I noticed is the interaction between the bands, the Dove article shows individual band bypass which can also be seen on the Opamp Labs EQ of similar nature.
I notice the Buzz MPE1.1 has individual band bypass switches, but the Purple, Peters EQ and the Buzz 500 EQ do NOT.
Have you guys - not found an issue with bands interacting in a manner that didn't always sound good?
This picture shows the 50Hz inductor LF peak affected by a CAPS MF whose gain pot is set at midway but the resonant circuit is not bypassed. Look at the effect on the 50Hz curve as the freq pot is varied on the CAPS circuit:
Also, with the bands set with gain at midway (no cut or boost), the CAPS freq pot has an affect on the overall frequency response.
This is the effect of the inductive LF band on the MF CAPS band (with the LF gain pot set midway) - loss in MF boost as freq gets nearer the LF band:
Bizzarely the 10k HF band produces some funny interaction - the curves are OK when the MF freq is high, but when low, the shape change is drastic (again this is with the MF gain pot at midway):
These are the lowest and highest freqs on the CAPS MF boost/cut, with curve interaction from the LF and HF (again both set with gain midway):
This is the change to the LF with the CAPS MF bypassed and unbypassed as shown by Dove:
This is the CAPS MF sweep with the LF unbypassed by gain set midway:
This is the CAPS MF sweep with the LF bypassed:
Hmmm interesting.
-Tom
