andre tchmil
my question is simple : which ones to use , which ones to avoid?
I need to clean a lot of non sealed contacts .
For pots I only use Deoxit Faderlube now.
ALL cleaners will remove the silicon loading from the controls and that will make your control "feel" change from a nice smooth motion to loosey-goosey. In the case of a slide pot, the pot will become tight and you won't be able to move it without it "catching."
The cleaners that lube do not restore the "feel" and are not designed to do that.
