I repaired a roland keyboard that had a cup of coffee.
The coffee etched away certain circuit board traces, which I replaced with jumpers (tedious). And it all works. But there is one problem.
The circuit boards have pairs of "contacts" that are under little silicone bubbles that are pressed by the keys. The bubbles have pairs of little contacts molded into them too. And when the key makes the contacts strike the circuit board contacts the circuitry measures the time between the two contacts to get how hard the key has been hit.
Here is the problem:
One contact has been corroded by the coffee. I need to replace the contact material but don't know what to use? Any ideas?
It is a grayish oxide looking stuff. You can see the one bad contact clearly in this picture, in the right hand half of the shot.
Any idea what I can use to resurface this contact?
