I've got this old tube PA amp that looks like an excellent candidate for conversion to guitar amp. Here's a link to the schematic I (hopefully correctly) traced out(I left out the very basic and soon-to be-replaced tone circuit):
http://home.att.net/~giuseppe_poteet/tr_tubeschem.pdf
When I hook a guitar up to it as is, the sound is a bit brittle, for lack of a better term. So I'm looking at possible changes to make it a little more pleasant sounding.
Some questions:
1. The plate voltage on the 6v6's is around 340v--higher than it's specced for. Should I pull it down a bit?
2. I'm considering dumping V1--I don't need the extra gain, & a lot of extraneous noise comes in at this point in the circuit. Shielding helps a lot, but I'm not sure the extra gain is worth the hassle of the extra noise.
3. The .01 uf's are ceramics--is there likely to be sonic improvement replacing these with mica or poly caps?
Any thoughts on schematic flaws, possible circuit improvements, or things to experiment with are very welcome.
Tom
Some questions:
Tom
