xtractor22
Member
- Joined
- Jul 24, 2012
- Messages
- 6
Hello,
I've been pouring over this forum for several days and have learned a LOT. (gotta love the internet). So first of all, thanks!
My question revolves around phantom powering a driver device (i.e. something that will send a signal to the mixing board). I have been looking at various schematics and reverse engineering circuits, coming back to this forum and saying, "oh that's what that RC filter is for" .
What I see is a lot of variation in the resistor values used to tap pin2 and pin3 for the common mode (phantom) voltage. I have seen everything from a pair of 6.8k resistors to a pair of 1k resistors. So my question is, is there some standard on what resistances can be used? Or is it simply a matter of headroom (max current draw across these resistors) and output impedance (dominated by the output stage/transformer. Don't want this resistor pair to have such a low impedance that it competes with the driver's ability to send ac). Not sure about this, but the max current spec I have seen appears to be 10mA. Assuming a pair of 6.8k resistors and this 10mA, the voltage drop would be 34V. Assuming 48V sourced from the mixer, this would leave 14V for the common mode Voltage at the driver.
I appreciate whatever insight you can give me.
